Wanted WTD: front engine bracket with idler pulley and rad fan hub
  • Thread starter Thread starter ed_ma61
  • Start date Start date
E
ed_ma61
Guest
heya,
im after a stock 1uz front timing cover/alloy mount... the X shaped bit in the middle/top that has the idler pulley and main fan hub built into it, and has the tabs of the AC compressor off to the sie of it.
can get a pic if theres troubles understanding what i mean.
doesnt matter if the bearings/fan hub are broken or whaterver, as they will be milled off anyway.
cheers
ed
Ed,
I use a SC400 bracket for my application. I dissambled the housing also. I have a used one that you can have if you like. However, flat rate shipping via USPS to your country is about $37 USD. Please let me know. No pulley by the way....
david, i may have it sorted at present. ill let you know inside the next week whether yours will be needed! cheers mate
ed
