Hi, I'm after the rear extension housing for my 1uz auto. The housing is the coupling / donut style and must have the speedo drive gear sensor spot which I think is pre 94 auto as the later type do use the speedo drive. I also need the 4pulse trigger wheel for the abs and worm gear mounted on the output shaft also that's visible once you remove the extension housing.
