Wanted WTB "Drive by wire throttle"
Crambo
I am after an accelerator foot pedal / electronic sender unit? for a "Drive by wire" throttle system, this is to be used on a 1GZ V12, ATM I presume other versions will be adaptable.
I have to do more checking but I thought I would see what's out there.
drive by wire throttles have to be spot on match with the std ecu
so beware incase u waste your money on ones that dont work
your better of getting one from toyota
u need to have the voltage readings exact of ecu will shut the throttle down
if they are abit out
i have done many fly by wire toyota diesel engines and if the pedal has any probs they wont run
Thanks for the info sideshow, it would be better to run all after market control, the road authorities don't allow it but I may have to cheat a bit.
The car has to go through a tough engineering test.
Maybe the good thing is they will have never seen one of these engines!
