I need the engine harness to piece together a new one for my new ECU, so if anyone has a cut JDM harness with good plugs, i need all injector plugs, and some other random ones to piece together my stand alone ECU harness.
Hello - you would be better to head off to a wreaker and collect plugs off other toyota cars. Injector plugs are always stuffed on 1UZ ( I have brand new ones) but mid 90s 4A-fe powered cars have the same injector plugs. Coil plugs are the same as 4A-GE , previa , most external coils which still use a distributor. That way you will get better plugs. Cheers
I know i need all the injector plugs first off, along with some others here and there. I am building a harness for my Adaptronic stand alone with a manual trans. Thank you all for your advice!!!
