autronic Member May 30, 2012 #1 As the title says, I'm interested in a "U2" auto bell housing, the one that have the engine tilted about 7 degrees vs. the auto box. Anyone ? - Trond
4 4U2QUIK Active Member May 30, 2012 #2 if you can't find a u2 bellhousing, I could easily do a 1 off adaptor with the pattern rotated 7 deg. if you're using it to adapt a manual tranny.
autronic Member May 31, 2012 #3 4U2QUIK: Thanks, but I'm after a U2 bell housing for a special application and the adapter plate for it I'll do myself.
4 4U2QUIK Active Member May 31, 2012 #4 I kind of forgot you're perfectly capable of designing/machining complex parts
