High volume fuel pump, fuel pressure regulator, larger injectors, autolite plugs.
Alternator would be swapped out for a larger one if necessary, don't need the one in the lextreme store when I won't be using standard mount points.
Header flanges from the store with custom made headers to fit in the space I need to use*, and a pair of VF10 subie turbos. I could always use beefier oneslater. Intercooler would be mounted in a good airflow path because this will be open engine bay construction.
Then I would just have a heated 100shot bottle, dry throttlebody system.
ECU would be a megasquirt.
*I know custom headers will cost more than getting Tundras, and if the Tundra headers fit, I'll use them instead, but I have a set space to work inside / around.
Would I need to harden the engine in any places to run this system, or would I get some punchy power this way? From what I've researched, as long as the tuning is good, pre-98 1UZFEs can take up to around 600rwhp without significant issues. My main concern is actually breaking the sandrail's axles doing wheelies.
