I'm running a 1992 1uzfe from an LS 400 on a Wolf V550 ECU. The engine was swapped into a 1992 4Runner and was running beautifully before doing a coil on plug conversion using Denso coil packs.
After configuring the Wolf V550 to run sequential fuel injection and individual coils, I can't get the engine to fire anymore. I think the issue is with programming the V550. I've checked the wiring 3 times now to ensure the coils and injectors are wired correctly.
I'm looking for someone who has done a coil on plug conversion using a Wolf V550 to compare ECU programs with. I think I haven't configured the ECU correctly since it seems like the firing order is off or the reference/sync signal isn't aligned correctly in the ECU.
If anyone has experience with the Wolf V550, I would REALLY appreciate some help getting this thing configured correctly.
Thanks,Rob
Thanks,Rob
