I have wired up a Microtech lt8s ecu to my 1uzfe. Everything looks to be working and wired correct, but there is no spark. I was not quite sure about the wiring of the igniters, because there was some diffrences between the diagram that came with the Microtech ecu and the diagram I found on the Lextreme webpage. But I followed the Lextreme diagram and think I sorted it out.
Is there any way I can test the igniters? I tried to measure the ignition outputs from the Ecu, but wasn't too easy. I did see that there was some voltage there when cranking. I tried the same on the outputs form the igniters, but there I got nothing.
All tips are apreciated!
