Which is shortest 1uz oil filter housing to suit hilux conversion?
wildsupra
Just wondering which model 1uz had the shortest oil filter housing or the best one suited for a hilux surf conversion?
Matty
In SA we have a GUD Z551 Filter with the same spec as the 1UZ filter same seal size and thread but its 67mm high instead of 100mm.
Its the same filter that the 107kw 2007 Volvo C30 2.0 uses
There is an industrial filter of a small grader, its like ~40mm high, mate used them for years with his 2wd Rn90 1UZ to clear the steering idler bolts/chassis. Can't remember the part number, but I found it on this forum, dredge through archive's you should find it.
