where is the engine number?
Mat Grant
Hi all,
I'm fitting a 1uz into a Lotus, it's from a 1992 soarer- I need to put the engine number on the V5 (UK reg document). Can anyone tell me where the engine number is and what the format looks like?
Any help appreciated.
Thanks, Mat.
Thanks mr Bushwhacker!
Btw are you still runing your 1uz with no expansion tank? I'm still unsure whether I an get away without one....
Cheers, Mat
Cheers, Mat
Yes.
I've done seven V8 Hilux conversions now and all have no expansion tank.
No reports of overheating or lost coolant. I did use brand new 3.0 diesel Hilux radiators though.
Thanks all,
XR8tt - how much do you have to remove to see the engine number? I've looked at mine, even took the plastic cover off that goes across over the HT leads, but still can't see it - maybe I need to get the wire brush out(?)
Cheers, Mat.
Here...
It is hard to see, but if you rub a greasy finger over it you can see it clearer.
(Or if your engine is spotless, try using some chalk dust:D)
Thanks!
It will have to be the greasy finger then..... :) Need to get the new engine number on the V5 at some point.
Cheers, Mat.
