V v8toy1 New Member Apr 20, 2010 #1 wondering what this sensor is im pretty sure i dont need it but its bugging me. the brown one cheers stewy
cribbj "Supra" Moderator Staff member Apr 20, 2010 #2 That's the one for the coolant temperature gauge on the dashboard. The one you've already connected to is the coolant temperature sensor for the EMS, and the big one is a thermostatic switch that controls the cold start injector.
V v8toy1 New Member Apr 20, 2010 #3 cheers i knew about the dash gauge one up top in the pic but yeah knew the green one was for the ecu so i guess ill pull the brown one out. and this might be a stupid question but can i put a 45 bend in he 02 sensor bung as i am short of room for it to fit at the mo.
cribbj "Supra" Moderator Staff member Apr 20, 2010 #4 Are you asking if you can use a 45 degree weld on bung, ie mount the sensor at a 45 degree angle in the exhaust pipe?
Zuffen Super Moderator Staff member Apr 20, 2010 #5 The sensor has to be immersed in the gas flow. Best solution s to plug the 02 hole and weld on a new bung in a location that allows room for the sensor's tail.
