I'm using the twin SVT supercharged Mustang throttle body on mine..
Twin 62mm ...
400rwhp is a piece of pee for the stock TB...jeez i made 400rwkw on the stock TBso don't get too worked up chasing big. A stock mustang twin TB at x2 57mm will be plenty big enough for your needs and still give good smooth response around town etc
Was that with blow through or suck through using the standard T/B?
Both when i did the twin charge set upBut generally blow thru on just TT.
I'm about to slot my now M122 equipped engine back in and it's just running a stock mustang twin throttle. I'm aiming for a similar 400rwhp...maybe a tad more, but i'll need a bit more boost from the roots i think so aiming to run approx 15psi with a 2.6inch SC pulley.
So you have had the M122 running in your car with the twin 57mm T/B?
Do you have any pics of your T/B adapter?
No part number sorry, but one of these will fit
http://www.efihardware.com/products/c225/TPS-Sensors-Kits-and-Parts
Yeah but which one Peewee?
Thnks XR8,
i was looking at one of these
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=310229088200&viewitem=&sspagename=STRK%3AMEWAX%3AIT
Pretty sure they are all 0-5v variable so it would be good to find one that simply bolts up to the Ford TB.
