What plugs are you guys using?
I'm doing NGK coppers too on this v6. I love them. Iridiums are better, but I'll take copper with FI. Copper just makes more since until you can honestly say you're done with tuning the engine & it's dialed in for life. Then when they plugs need changing, Iridiums.
The $$$ just makes too much since.
Autolites for NOS ia what I use.............I here NGK and the Bosche plugs are probably the best to use.....
What are the best spark pluig wires to use at a reasonable price? I used the Bosche wire set and can't tell if they are good or bad...Any thoughts on spark plug wires.....
Caps and Rotors I used Bosche too...
I even use a Bosche oil filter....
I guess you can say I am satisatisfied with the Bosche products in general.......
What do you guys think of the Split fire spark plugs? The spark plug that splits into two parts for what is supposedly a stronger spark...
Garbage or Gold?
Ngk bcpr 6 es. Used for fi application.
Have always used these on other fi engines, and are very happy with them. Cheap are they to.
