Hello
When installing a engine to a car that it has not been stock. How important it is for the drivesafth, that how high or low the engine sits in the new car? If totaly new drivesaft will be installed, does it give litle play for the angel it will be installet the engine and diff?
I'm making new enginemounts for my 1jz -> 200sx swap. Was thinking that is it ok if I sit the engine on little bit of plywood and then attach big enough metal sheats to the engine and the crosmember, and the just weld them together whit some metal. After thay are stady enough would take the them out and cut the extra metall of and the mounts stronger if needet by weldin some more matall to it. I just don't gnow is there eany specigications to the thicknes of the plywood I need to use.
Grats
Grats
