Hint, this is not about a BMW or Mercedes (or Lexus
First, some pictures.
Seats. "On the inside, 14-way adjustable Recaro seats keep the driver firmly planted in front of the steering wheel. Those seats, along with the shifter and steering wheel, are wrapped in a micro-fiber material that looks like suede but is easier to keep clean and isn't sensitive to moisture."
Wheels. "Nineteen-inch wheels are used at both axles with 9-inch wide units used in front, 9.5-inch in the rear. The wheels are wrapped in customized Z-Rated Michelin Pilot Sport 2 tires." "six-pot Brembo calipers do the work up front with four-piston units at the back. In this case, though, the 15-inch front and 14.7-inch rear rotors are made of steel with aluminum hubs and slotted surfaces"
Brakes. "six-pot Brembo calipers do the work up front with four-piston units at the back. In this case, though, the 15-inch front and 14.7-inch rear rotors are made of steel with aluminum hubs and slotted surfaces"
Interior.
This ladies and gentlemen is the 2009 Cadillac CTS-V with a detuned version of the brand new Corvette LS9. 6.2 liters, supercharged, 550hp, 550tq.
Transmission choice is between a 6 speed manual with a dual disc clutch OR a 6 speed dynamic automatic.
http://www.autoblog.com/2008/01/08/detroit-2008-2009-cadillac-cts-v-revealed-with-550-hp/
Interior.
