B beario New Member Jun 10, 2009 #1 can anyone suggest a place to get a w58/1uz flywheel clutch w58 spigot bearing hydro realease bearing and adaptor plate for w58 so when bolted up it all works...and prices and links if poss...as cheap as possible...or caD DRAWINGS i am in uk...
MWP New Member Jun 10, 2009 #2 Spigot bearing is common, part number 6201. See here for a U1->W58 adapter plate cad design: http://www.v-eight.com/tech_forum/viewtopic.php?f=40&t=753 As for the rest, youll have to find out whats available locally. It wont be a bolt up job, youll end up needing to get custom work done.
T Tonyd Member Jun 10, 2009 #3 Have you tried THOR racing at Warwick. They have lots of 1UZFE goodies including gearbox fitting kits for the Lexus V8s. Cheers, Tony
B beario New Member Jun 11, 2009 #4 i would not use thor racing for zip dude...had some bad issues with that place,and thats all im saying...
M mikeywaysc400 New Member Jun 20, 2009 #6 toyosoarer.blogspot.com scroolll down to the bottom and check out the link.
