Christopher W.
This is a cover my arse purchase....meaning get everything I might possible need to get this up and running.
I am buying a US 2000 GS400 1UZ-FE VVTI engine to put into a 1987 Toyota 4Runner. I will be running stock ecu and using a piggy back system.
I have found a US 2000 GS400 (not the same car the engine came from) that I am buying the US ecu out of. It is not available for me to look at as it is many states away.
I am wanting to buy anything that might be related to getting this up and running all from the same vehicle in the hopes of not having any compatibility issues. I have got anything and everything between the key, ignition switch, wiring and boxes (two) to the ecu. I also bought the instrument cluster just cause I thought it might be cool to swap into the 4Runner..
The car my engine is coming out of was drive by wire but was changed to throttle cable when they went to the Accufab throttle body. No wires needed..
I want to get it all from this one car. If I am not sure, I am going to buy it anyway and if I don't need it I can sell it later or whatever.
Is there anything I am missing??
Any input would be appreciated!!
