I have just done some more 1uz VVti engine wiring and made a short video of the bypass unit and posted it onto my business facebook page
https://www.facebook.com/TheCartuneCompany?ref=hl#!/TheCartuneCompany
I have 8 more ypass units which I am presently working on and more coming from overseas. Each one takes me a while to make and then I like to test each on on a running motor. I have a process that I work through of testing the ECU before starting. I have had 2 ECUs that are faulty , I suspect from dismantlers being rough or water damage. These ones dont even communicate with the scanner from the beginning. One was mine and one a customers.
I have one at the moment which has the same numbers as other I have done but brings up a completely different set of codes. Normally a security ECU brings up that there is no communication with the immobiliser but this one ECU brings up body control ECU fault , door open switch fault and only after trying to start an engine with it does it bring up no comms with immobiliser. That one is going onto my experiment shelf. I will look at that one later.
