Is there any common things that cause oil leaks that is not vc gasket related? It seems to be below the vc gasket.
I picked up a 98 ls400 for my wife and did the vc job right off the bat thinking that would do it however it seems worse than ever before as it has the whole bottom of the car coated in oil and leaks about a quart ever 100 miles or so which I can say it is not coming from the front cover area or the ps pump and seems worse on the passenger side so I thought maybe a head gasket so I did the compression test along with leak down as to which it is all about as perfect as you can get.
So I turn to my fellow uz friends for any input on this.
Thanks in advance![Smile :) :)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
Thanks in advance
