V8 3uz-fe VVT-I fuel problem
Oskido
Hi,
Diagnostic Test done and following is the problem - crank, short idle dies:
On the home diagnostic I'm getting the following:
Fuel Cut Solenoid signal problem detected (where is this situated on the motor)?
EDU (Electronic Drive Unit) malfunction (where is this unit situated or is this part of a ECU problem)
Please can you assist to help repair/fix?
