when I go to put a picture on it tells me it's too large but if you coming out of the block or two half inch long metal pieces they look like it holds the belt from being able to jump teeth
Are you referring to the pieces that normally sit under the crankshaft timing belt pulley? If so they are there for help fitting belt. As long as oil pump isnt cracked i would say it would be fine without them.
