How do you know what precautions I have taken?
Well unless I missed it in your oversized images I can't see:
1. A purge valve?
2. Fuel pressure safety cut off switch?
3. Nitrous pressure safety cut off switch?
4. The pipes to the jet are too long from the solenoid.
5. You appear to be spraying up stream of the throttle butterfly and you are too high in the plenum so most of the nitrous gain of taking a gas in liquid form and having it expand to dense atomised gas in the piston is lost?
7. Have you got 2 fuel lines, 1 for normal running and another seperate feed from the tank seperate pump to provide extra pressure when armed?
I'm not familiar with Autronic but:
1. Can it run instantaneous 3 widely different fuel maps?
2. 3 different timings or constsntly adjustable timing?
3. 2 different limiters, 1 for nitrous flow and 1 50 revs later for spark?
4. Can it manage a progressive Nitrous and fuel flow to limit drive train shock?
All above with the caveat of struggling to view your large posted images.
You have obviously spent a lot on your engine but a cheap job on dumping an extra shed load of horsepower is always a false economy. Personally If I was you I would go with 1 big high flow set of individual foggers (wet system) and a progressive controller.
You will save on only needing 1 set of foggers, but will spend on the controller, however you will get the max from your engine rather than getting a half response and possibly destroying various components.
All comments meant with sincerity and as I said I'm not pissing on your fire.
M
