lex, the only problem i would see with running 18-20 psi is fuel. at that boost and 9.0-1 cr you're gonna need some serious octane. i dont' know whats available where you are, but here in ND (don't laugh) the best we can get is 92. even here, at that, you'd be looking at running 92 and octane booster with EVERY tank of gas to stay out of detonation. i'm sure you could do it with a cr of 8.0-1, but then your motor would be alittle sluggish while off boost.
and i agree with vn1uz about the stand alone ems. but if thats not something you want to do, there should be some way around it. what have you found is limiting you to 16 psi?? is it the maf??? if so, maybe a 2jzgte maf would help. supra guys get rid of them ASAP and i don't know what the flow limit is on one, but if its on an engine rated to create 320 hp, i would say it probably flows better than the maf for the 1uz.
and if this is something you're aware of, please don't be offended that i told you. in forums, i've found its most helpful if you take nothing for granted and cover all the bases. sometimes it offends people, but thats just a chance i take i guess
