speedaddict
Is anyone here on this board familiar with the tundra auto trans? What is the actual name for the tundra tarns, A340? I would really like to be able to control the shifts via a paddle shifter, ratchet shifter or gate shifter. I’ve been told the stock tundra trans uses 4 electrical solenoids that open and close pressure lines, which in turn shift the gears. Based on that information I’m guessing an electrical paddle shifter is my best option, since I have yet to find a manual valve body for the tundra trans. Is it possible to rig up some kind of device that will send a signal to the four shift solenoids to make it shift when I want, without causing the stock ECU to go into limp/safe mode? I’ve come across this company, http://www.twistmachine.com/products/shrifter.html ,which make a universal paddle shifter designed to be used in conjunction with this stand alone trans controller http://www.powertraincontrolsolutions.com/content-4.html , which completely replaces the stock tundra trans wiring harness. The PCS setup will not work for me because I still need the stock ECU to recognize a tundra trans behind the motor specifically because of the load sensor. I would like to use the universal paddle shifter and figure a way to make it work with my stock trans harness. Any Ideas? Thanks
