this is possibly the worst picture ever drawn on paint, but you should understand me. what im trying to do or get approval from people is this. mount my two t3t4 turbos on the left hand side of my ute similar to a rb 26 high mount set up, about 15 degrees offset to the left guard as there is no room to put them at the front of the engine or on side by side.
Now what i want to do from the right side i want to run it under the back of the bell housing to the rear turbo this will be double heat wrapped to keep heat in. then its 2.5'' off the back of the turbo, equal length or as close as, then a equalizer pipe about where the gear shifter is, a guy at a exhaust shop said it will work but has to have equalizer pipe. ( pipe that joins or kisses both pipes then goes back into twin separates)
my questions.
A. will this work?
B. will it still have a nice note?
c.legal noise ( has twin magna flow 2.5'' mufflers 9x4''
if its a big no no. i cant afford a single. and will go n/a but wont be happy about it.
simple drawing of what i mean not to scale.
By dean_ako at 2010-07-20
my questions.
A. will this work?
