trying to locate integration relay
mista808
94 ls400
i suspect that i have burnt out this integration relay. all fuses are good, and most of my interior lights work. the ones that dont are the lights under the dash where you feet are, and the dome light in the DOOR position. did reseatch on other lexus forums and this integration relay seems to be the problem. does anyone know where this relay is located. i took aprt the lower dash section on the driver side and could find it. perhaps i wasnt looking hard enough. i also noticed that denso labels their relays. its said that its behind the fuse/relay panel under the dash, just to the left of the steering column. but i couldnt find it... maybe someone here knows what im talking about, and where it might be located. all help is greatly appreciated.
