im not sure how this will bolt up?
if you have a look at the manifold bolt pattern, it doesnt line up with the manifold of a vvti?
i was thinking that you may have to pull apart the vvti manifold to mount this to the engine, but after looking at the manifold and the head, none off the bolts line up?
so its got me puzzled how this will work
____________________________________________
http://www.lextreme.com/forums/showthread.php?t=9037
:sgrin:There is No substitute for cubic inch, except for BOOST !!!!:sgrin::burnout:
"91 LS400" Argo rods, CP pistons 9:1, Custom Tighte Cams, Whipple supercharger 20psi, Torsen Lsd,
Dual TB's, Whiteline swapbars, 97 RZ Supra brakes, Airbag & controller
