Thinking of getting one of these made for my lux. I also want to install an electric water pump so that when the motor is working slow in the rpm say 1500 to 2000rpm but under high load the water will still be pumped quickly to help with the cooling. Can I just simply put an electric water pump in the system with the standard water pump there or will the standard pump slow the water back down again if its only pumping slowly at low rpm`s.
