Transmission Problems (no selective anything)
Kirby
(LS400 1UZ- Crown auto in hilux)
I have a transmission problem lads.
For some reason i don't have selective 1st or second. correct me if i'm wrong but 1st is first and second is 1st-2nd. If i select 1st and accelorate it'll go 1,2,3. if take my foot off the accelorator it will all of a sudden pull 1st and lock up. it seems like it doesn't know wat gear its in, it will drive fine in D. over drive kicks in and does everything its meant to do, but if i'm driving alone and pull it to second all it does is pull itself out off overdrive and hold third.
I've checked fluid, transducer, all conections, done a million changes on ratio box. Ohh it only started doin this after i put the transducer on. any ideas??
Cheers Kirby.
double check the wiring to the auto ecu
there are afew wires which tell it if your in neut or rev or 1st or 2nd
u might have them wrong
who did u buy the ratio box was it venom
i did mine a different way much easier and less fiddly
but if its because of the ratio box it is possibly a wrong speed signal
Cheers mate,
My computer is intergraded so i wouldn't know wat i'd be looking at without a wireing diagram.
i got my ratiox box and hall effect transducer from veno....Is this a problem?? i've asked him why its doing this but he didn't say much.
if it is the ratio box and wrong speed signal, how do i correct it?? would venom have known it would do this???
if u have integrated auto and engine in one ecu u dont need a ratio box
u can use it but its a waste of money
just throw it out
all it is for is the back up speed sensor
but the factory loom has a main speed sensor to it
did u buy loom from venom too
i do my 1uz looms different to him so i cant judge what he does
anyway just leave it out
Yeah mate got the lot from venom.
I unpluged the ratio box, but it just cuts out around 2500, is this because theres no speed sensor? i thought the ratio box took over the speed sensors job. if i chuck the ratio box what goes in its place?
Is it easyer put the old transducer back in and get an electric speedo??
u didnt say u had rev cut in yr first post
is it at same spot every time
if it is its in limp mode and u have wiring problem
u should not have used the crown auto with the ls400 ecu and engine
always causes headaches and i guess u have one
crown has 2 sensors on back
one of them has 32 pulses per rev of output shaft
ls400 needs 4 not 32
so u have to reduce the 32 to 4
but i doubt this will cure yr rev cut
ive had this prob afew times many years ago and i took ages to sort out
i would look at yr loom again
u should be able to rev it to 6500 in nuetral and if u cant u have a problem
ive done 80 1uzs and never had a rev cut due to speed sensor
anyway send it back to venom
unless u want to pay me to look at it
Naa Its not in limp home mode mate, pulled codes and had 56 and TPS sensor. The rev cut is only in N and Park. It will rev to 6500rpm in drive but if i diconect the ratio box i have a engine cut in gear.
Its fine to drive, drives beautifuly, i just don't have manual 1st or second.
I think i'll put the original transducer in it and go without a speedo, i know that way everything is perfect apart for the engine cut in N and P.
I asked venom about the Crown box with the LS400 because i read on here that it was bad news, he said it would be fine.
Also, i thought the engine cut in N/P was something to do with code 56. I read on a forum that if i ground the blue wire on the back of the ecu (dun remember PIN or Plug) it sorts itself out. apparantly its low fluid level for hydrualic fan.
cheers for the help
its fine if its all wire up right
like i say take the fuking thing back and get it sorted
people pay too much money and then end up with problems
i am never like that to my customers i always try to make it perfect
anyway u need to take it to someone to look at it
i just told someone else off on here cause they dont realsie how hard things are to fix on the forums fukinnngng hard without looking at the car
like i tell everyone
bring car to me and ill fix it in 30 minutes
u have to understand speed signals and the differences between the ls400 and the crown
on this interface box what model is it
6100 or a 6102
for the ls400 u need a 6102
they are not cheap
send me 600 bucks and ill stay on the phone all day and help u hehehehe
otherwise speed signals are very complicated
if the speed sensor u r using is the speedometer one then u have used the wrong speedo sensor on the crown
i know the electrics on these boxes alot and i think u have used the wrong sensor
basically the sensor that srews on is for the speedometer
the sensor that has a 12mm head bolt iis the one for the speed signal to the ecu
u need to convert this one
anyway im sick of fixing other guys fukupppps
im off to do some work
