I am doing a little side project using the rear mount method. However, I noticed the transmission lines and pan is right near the turbo. I wonder if it is ok or feasible to use transmission oil as a turbo lub and cooling medium. If I am able to use transmission oil for that purpose, then I will surely put in a tran cooler. Any feedback will help alot.
Thanks
david
Thanks
david
