Transmission and transmission cooling ideas and or locations
Been having a hard time with my transmission. The first transmission was burnt due to a bad leak on a 7hr drive. Now I have a new USED transmission with new solenoids, filter and new transmission oil install and on SHORT drives to the store or on a highway, it drives like a Lexus. Since my last 7hr drive, I’ve been nervous driving it anywhere longer than an hour.
Just the other day, my transmission gauge temperature hit the 200 temp and my transmission didn’t want to shift from 2nd to 3rd gear. Check the fluid and it was still red and clean with no burn smell or anything. But my transmission cooler was really hot.
Transmission cooler is from a 90’s Ford F150 V8 truck. It is located inside the engine bay with 2 fans. The cooler is 11inches long by 5inches wide and 2 inches thick, the 2 fans are 4 inches. The 2 fans are constantly running but I NOW know it NOT enough to cool it down.
I don’t have adequate room in the front to mount this cooler, since I have the radiator & AC condenser and on the side a Cadillac El Dorado cooler for the Power Steering. I also have a winch that is dead center of everything.
I am considering relocating my transmission cooler to get more cooling.
Should I put in a hood scoop to direct more air in that area?
Should I buy a bigger aftermarket oil cooler and add a bigger fan?
Can I mount this cooler right on hood with a hood scope with 2 fans pulling air?
What would be your idea?
Anyone have any recommendation?
