stevechumo
I've found my tranny on my SC400 is leaking fluid badly. I thought it leaks slow but after 4 months after I had it full, I checked the dipstick and its tip barely had any fluid. I then re-filled the tranny up to half way between the cold and hot range on the dip stick while the engine is hot.
The tranny oil pan's seal is not leaking. I replaced it 4 months ago. I couldn't find the exact spot where it leaks. It seems to be somewhere near the dipstick's housing entering the tranny fluid pan. But it's not right at that spot. The leak seems to be higher. So I'm asking for help on this problem. Does anyone have any ideas on this?
Any info. is greatly appreciated.
