TPS and Knock Sensor Pinout Question
Drift99
Hey guys. Im about to wire up my safc2 on my 92 1uz and would like someone to confirm ive got my pinouts right. I ask because there are more then one of the same pins. I found two pins for Knock Sensor E9-3 and E9-11. Also two pins for TPS E9-1 and E10-4. Im not sure if I should "Y" the two TPS pins together? Same with the Knock sensors?
There is also a pin thats says TPS/Air Flow Meter which is E10-11. I guess I shouldnt need to use that i assume?
Wiring is not my thing. I would really appreciate if someone could take a few minutes to go over this for me.
you ain't need the 2nd (electric motor driven) tps as it's solely used by traction control ecu
don't mix the left and right knock sensors though as the results would be unpredictable (other than the car not driving normally)
Both VTA1 and IDL1 go to main TPS (cable driven). Knock sensors, you should use both . KNK1 goes to driver side (LHD) sensor
Thanks George,
So I just use either one of the TPS pins? And for knock I use both so just Y them together? Almost ready to start wiring this thing lol. Thanks again.
No
There're 2 knock sensors, each needs its own separate wire. One goes to KNK1 and the other to KNK2. Connecting KNK1 and KNK2 together will lead to unpredictable results
Main and sub TPS both have equal pinouts as I can recall. Each of them must have 4 wires: power, earth, sensor output (VTA) and closed throttle detector (IDL).
You only need to connect main TPS. All 4 pins of it. But don't touch the 4 pins of sub TPS
Alright so I guess I will need to try hooking my safc2 to one of the knock sensors and see what happens. The safc2 only has one wire for knock.
The safc2 has only 2 wires related to TPS (one wire being TPS-in and the other TPS-out). I guess I will wire TPS using VTA1 and see what happens.
Please let me know if you have any other ideas. I really appreciate your time/help Geore.
Here is a diagram of the safc2
Sure, use any knock sensor. It will be ok unless there's some fault in only one bank
As for TPS, use VTA1 only.
Thanks, I will give that a try.
Only thing im not certain about is the power wire. I was going to wire to pin E11-26 BATTERY but after a bit of reading, i found out its constant for memory. Any idea what pin I can use for power?
Thanks a bunch
BATT is constant
IGSW is ignition barrel output (intermittent)
+B,+B1 is main relay output (intermittent with delayed shutdown)
Thanks I will try that George!
I am using power from the radio right now but need to change that because the safc is loosing power when I crank the key to start the car lol
