Bryan, your welcome..
If your suspecting a problem with the TPS you could easily check it.
If your looking at it as mounted on the TB, measure the resistance between the TOP and BOTTOM pins.. It should be at least 3K ohms but not more then 7K ohms... As long that is fine, then check between the TOP and SECOND DOWN pins. The resistance value should be high but still probably less then what you measured in the first step now slowly open the throttle and the resistance value should drop in a nice linear fashion as you open the throttle in a slow linear fashion. If you see a sudden decrease in resistance but there wasn't a drastic chance in throttle movement, then you could suspect the TPS. If the drop in resistance is nice and linear, then I would forget about it being TPS related..
