speedaddict
[FONT='Arial','sans-serif']I know this board is dedicated to the 1UZ-FE but was hoping someone had experience with the tundra 2UZ-FE. I transplanted an entire tundra drivetrain and wiring harness into my 95 Toyota T-100. I purchased the motor 2 years ago from a wrecking yard that told me it was out of a 2004 acces cab (extra cab). Since then I have come across information suggesting it is possibly a 2001 1)fuse box is rectangular rather than an L shape, 2) there is a fuel send back on the fuel rail rather than built in on fuel pump. The motor will crank if I send current on the starter solenoid wire, but doesn’t seem to be getting fuel or spark. I don’t have the tundra ignition tube or key so I simply tried to hotwire the acc, start and starter wires. Out of the six wires I attempted to hotwire only one has voltage (.7 volts). There are two fatter gauge wires (white with red stripe 8 or 10 gauge) which I assume go to the sarter relay and the other 4 are for acc and start position? The one wire that has the .7 volt is one of the 4 smaller gauge wires (10 or 12 gauge). Does anybody have access or know where I can find a wiring diagram showing the starting layout? I also need to find out what year motor I have, I plan to call my local toyota dealer and see if the can tell me anything from the numbers on the ECU. If they can’t are there any other known differences between 2000 and 2004 2UZ-FE motors? The pic below is the truck the motor is in. [/font]
