C coop-77 New Member Oct 21, 2009 #1 hey guys does anybody know te head torque settings for a 1uz cheers jason
XR8tt Active Member Oct 22, 2009 #4 They will be torque to yield bolts..32 nm then 90* centre out.. Check what bolts you have etc..
Lextreme II Active Member Oct 22, 2009 #5 One problem is that stock spec might be optimum due stock gaskets are softer then the MLS.
XR8tt Active Member Oct 22, 2009 #6 Its all about bolt stretch .. TTY torques them the same no matter how tight thread etc is.. Check ?? Some do.. 32nm / 60* then 60* centre out.. They are only 10mm bolts..
