fugazirpm406
Please Help!
I have transplanted a 1UZFe into my Toyota SR5 :shocked: and have had a Microtech computer fitted by the Auto Sparkie ( has fitted two similar set ups in the past).
Have also replaced the cam belt, rotors ,caps, sensors, leads etc.
The cam timing has been checked by three different people and all marks correspond correctly on this engine and are the same as one yet to be serviced.
To get the engine to run requires the cam sensor wires to be reversed causing an RPM error. This in turn makes the vehicle un drivable from around 2000 - 3000 rpm.
With all the sensor wires in the correct configuration the engine is trying to run 30 degrees advance on the timing light.:headache:
The Sparkie has scoped all the signals with a SNAPON box and they appear to check out.
We have also swapped the ECU with another proven unit.
Still no joy!
It would be fear to say at this point we are fresh out of ideas , possibly over looked the obvious and we would appreciate any help we can get.
Still no joy!
