time to build exhuast any ideas?
jack
hi i am nearly upto the exhuast stage of my ma70 1uz swap any ideas on exuast i am thinking single and i want to leave room as i am more than likely going to tt it
Yes! I've recently done my sc400 vvti exhaust. I upgraded the pipes to 2.25" all around, removed the center cat, removed both resonators, and kept the original mufflers. When you drive normally it's only slightly louder than stock, but with more of a deeper rumble. Once you drive hard, to me it sounds pretty close to flow master mufflers. It's nice and I think you'll like it. Off the line the car peels out all the time. When it was stock it would peel out only once in a while. The only problem I have is I went with the h-pipe setup and after driving for a few days, the check engine light is now on. I'm not positive it's the exhaust, but it may be. I think I might converted to a y pipe instead.
