Simon that's got to be painful....... shaft leakage, and leakage from butterfly misalignment seems to be a common problem with aftermarket ITB's, especially those that are custom fabricated.
I've even heard horror stories of mismachined manifolds where you could hear the motor's idle change as you torqued the manifold down because the manifold didn't match up to the motor well enough, and the torquing caused misalignment between the TB bores and butterflies
I'll be putting 6 sets of 2bbl TWM's on my V12 project, and I sincerely hope those puppies don't leak. The builder tells me he was able to get his last motor with them to idle smoothly between 850-900 RPM. I sure hope he's not blowing smoke....
Oddly enough, I've not heard any problems with the el-cheapo ITB setups using bike throttles. Anyone else?
