Oil pan came out pretty good. I'm happy with it. Does have one thin spot and one cold shunt. Both very small (smaller than a dime) and will be easy to touch up with TIG. The casting came out rough (surface finish), but I expected that as I poured hot since I was worried about it being such a large/thin part. I planned on smoothing the inside anyway, and will probably do the same on the outside.
![IMG_2838.JPG IMG_2838.JPG](https://www.lextreme.com/forums/data/attachments/11/11563-e2c05d516f4c0f26c48e8d937e602d60.jpg?hash=4sBdUW9MDy)
Two part resin/sand mold. Weighs over 200lbs.
![IMG_2840.JPG IMG_2840.JPG](https://www.lextreme.com/forums/data/attachments/11/11564-0c68944a7061ccbf2debed484d36693a.jpg?hash=DGiUSnBhzL)
Ready to pour (no I did not pour it in my garage)
![IMG_2844.JPG IMG_2844.JPG](https://www.lextreme.com/forums/data/attachments/11/11565-a109230a952a0dab06c4752e6d71252c.jpg?hash=oQkjCpUqDa)
Melt ready to go (wire is the thermocouple for monitoring temperature)
![IMG_2845.JPG IMG_2845.JPG](https://www.lextreme.com/forums/data/attachments/11/11566-a249f6d0e7c97cad624eb5d9bd956322.jpg?hash=okn20OfJfK)
Mold opened. Notice how much the sand was burnt. This is a combination of pouring hot and having probably a bit too much resin in the sand. In any case, this results in a rougher surface finish on the casting.
![IMG_2846.JPG IMG_2846.JPG](https://www.lextreme.com/forums/data/attachments/11/11567-7c908f6f8ac1e333a1352b9df0d05bf9.jpg?hash=fJCPb4rB4z)
Outside (bottom). With runners/sprue/vents still attached.
![IMG_2847.JPG IMG_2847.JPG](https://www.lextreme.com/forums/data/attachments/11/11568-b185414f2d30d82b674bec0051d852b8.jpg?hash=sYVBTy0w2C)
Inside. Pattern in the background.
Size came out perfect. Aluminum shrinks, so the pattern has to be sized appropriately. Can't say I have enough experience, but others are a wealth of knowledge - I just leaned on theirs and all came out good.
This pan allows for 5 evac lines (passenger side) and 1 turbo drain back line (drivers side). Just clears the rod bolts. I'll machine the pan for AN10 ORB fittings.
