thermosat hose to top or bottom of radiator??
bluespoon
can any one tell me which radiator hose goes to thermosat on 1uzfe???. and do pull electric radiator fans werk beter than push fans???
The bottom hose on the radiator on my 1990 Celsior goes to the thermostat outlet.
Push or pull, both work well. which ever fits in easier.
Perhaps fitting fan between radiator and engine would be perferable then the fan doesnt block air flow when driving.
Any fan is vastly more efficient pulling air rather than pushing it.
If at all possible put the fan behind the radiator.
If you have to mount your fans in front of the radiator make sure you check with the supplier that the fan is capable of being converted from pull to push. The fans that I used are not and had to be ordered as pushers, but still work fine.I have no engine driven fan and only 2 small push fans mounted on the a/c condenser (a 10" and a 9") the condenser is sealed to the radiator support and the support is sealed to the radiator (so air can't escape from going through the radiator) and on a 35degC day stuck in traffic the fans are still not running constantly and temp gauge still sits on half way.
