Brandon Roku
So I'm building a front facing intake for my 1uz. So far i have the intake plenum cut at about 6" of clearance between each individual port on the lower runner. Basically, the mainlower intake plenum is now 2 plenums cut about 7-8" from the mounting plate. Not horribly uncommon.
My question is: since i will be running a throttle body directly over the thermostat intake valve, and directly through the water transfer bridge.. Has anybody mod'ed the bridge or thermostat area od the block to allow for this as of yet? Ive fou nnnnd similar things, but nothing that conpletely clears the area. Just need a design to follow if possible.
Regardless, this might turn into a build thread considering its going to happen weather i find a design or create one. Hoping someone has info!!
Thanks guys!
Thanks guys!
