There is no TH400 that will fit to a 1uz directly, a special adapter plate and pump must be used, the stock bellhousing must be cut off. Than you can bolt up any A34xx bellhousng to that adapter plate.
Stock TH400 should take at least 350hp with ease. Fully built ones handle 2000.
