tb48de 4.8 v6 engine vs 2uzfe v8 engine
thalj
hi im a toyota fan and i wanted to ask about the tb48de engine found in a nissan patrol.. its is a 4.8 dohc inline engine..
my question is the 4.8 v6 engine found in a nissan patrol stronger than the 2uzfe v8 engine found in a toyota tundra when turbo charging it ?
i know stock vs stock.. nissan is stronger due to its wieght and power.. but what about modifications.. if anyone knows about this plz post.. :)
I'd say heavier and stronger ???
Depends on engineering but imo straight six's are stronger due to amount if mains....
Nop i mean the nissan body weighs more less and a toyota tundra..
anyways is the 4.8 v6 inline stronger in modification than a 2uzfe v8 v engine
back to my question. do you know what the V means in V6 or V8? its not just a randomass letter people like to slap in front of motors, it does have a lot of meaning, and it does not apply to all motors.
Not having anything to do with engine itself... Its a straight 6 btw...
I wouldn't hesitate to fit turbo or forced induction to one...
I usually fit low comp pistons and replace rods.. But if your after 36% power gain and 50 % more torque ?? Go for it...
It seems a new thing to fit late model 4 wheel drive engines in sedans lately and turbo them.. There's an old Toyota Crown going around with a Landcruiser 4.5 6 cyl, turbocharged .. It pulls low 12's on the 1/4...
In N.Z there was a guy fitting a Nissan 6 with turbo conversion to an old 240K / Skyline... Truck style engines SEEM to be stronger in rotating assemblies.. Though I wouldn't rev them high I would say they'd take some boost....
but you guys didnt tell me what you think .. is the 4.8 6 cylinder inline from a nissan patrol stronger in modifcation than a toyota tundra v8 2uzfe engine ?
How long is a piece of string?
Dollar for Dollar I think the Nissan would win.
Whilst it's not known for revving that's fine in a 4be.
They are not an economical engine to start with so once you start modifying them you will need a big fuel tank and an equally big wallet.
THe 2UZ suffers weak rods and replacement rods are not cheap.
that MS75 crown coupe has run a 10.75 using a turbocharged 1FZFE with a custom inlet plenum.
"truck style engines"...? i take it you mean inline engines...?
i would turbocharge the Patrol six personally unless you plan on upgrading the 2UZ rods to Argo or Carillo or whatever.
the nissan inline sixes are pretty stong units, getting a good sized turbo on them shouldn;t be a problem as their rev range is comparitively narrow so use a big exhaust housing (1.00 A/R or bigger) with a BIG external wastegate and a 0.6 or 0.7 A/R compressor housing. Your exhaust manifold pipe size should match your exhaust port size (or be >just< smaller than) not unlike the setup Dazz used and you'll be laughing all the way from idle to redline.
The Crown was at Wsid / Eastern Creek and run Autronic...
Was having issues with over fueling....
