T56 throwout bearing
rscob
Can any of you guys tell me what type of fittings are on the t56 throwout bearing i think they are an4 7/16 thread as i need to buy the fittings to make up my hydraulic lines.
Cheers rob
one is a m10X1.5 and the other is a slip fitting retained by the roll pin.
Thanks for the fast reply but i already have them fitted to the bearing its the fitting size from them to make up the lines,doe's this mean the thread size is m10x1.5 that i need .
Cheers rob
For the roll pin fitting, it depends on the fitting you use. Russel Performance makes two (640281 and 641001). One is 3an on the other end, and the other is 4an.
For the bleeder line, it again depends on the other end of the 10×1.5mm fitting you used.
Where did you buy your fittings?
