So here is the jist of the install:
3" polished aluminum pipe
12x24x3 intercooler
ATI P1SC With Lextreme Bracket
autowerks bypass valve
walbro 255 hp in tank
3.9" pulley
ngk v power bkr 7e plugs
stock everything else
custom made front hood support bracket because I had to remove the original for the front mount, as seen in pictures.
had to do a bit of grinding on the front, near the head lights where the intercooler pipe comes up and down near the end tanks where the pipes come in to meet the intercooler.
The biggest issues I found was trying to figure out the idle issue like we spoke about and the intake pipe to the procharger. I had to do A LOT of fine trimming and grinding to make something work. You don't see it in the picture yet because I haven't got the filter. Also the horns need to be relocated, as seen in picture. I will update you with the pic. I only want to run somewhere around 4-6psi that way not having to worry about detonation. I'm not planning on driving it until i have a wideband and boost gauge. You say that with the 3.9" I should be somewhere around 6psi?
Erik P.
12x24x3 intercooler
3.9" pulley
Erik P.
