-Nemesis- New Member Nov 11, 2009 #2 My gas is vapour EFI, plumbed into the lower intake manifold. If you can get the tune right, it loves boost. I hit 10psi through a FMIC last night, after finally sorting out my Romano system after a year, it held 12.5:1 to redline!
C Cobber New Member Nov 11, 2009 #3 so you are running the std lower manifold right? I'm talking about the open lower manifold used by PD superchargers. Good to here it is running well. I believe there is an issue with not having long enough runners that causes gas scavenging to other cylinders. A friend is looking to run an Eaton on his LPG gas vapor injected car but has been told the lower manifold will require tubes welded into it. I was just wondering if anyone had successfully run gas vapor injection on a PD supercharger with an open plenum.
-Nemesis- New Member Nov 12, 2009 #4 Yeah sorry, stock manifolds. I remember Neil kept telling me either style will be okay (PD or Centri) but I'm not sure what he had planned for the open manifold.
-Nemesis- New Member Nov 12, 2009 #6 Yeah it's chalk and cheese, that last few thousand rpm is just awesome. And that's in a 2.2t truck!
