I have a 99 Lexus 400 and I have the problem where when you go over a
small pot hole or a bump, there is that THUD as though the front
suspension has no shock action - otherwise the car rides well and the
shock action is as expected. I see that you had posted a solution for
this issue - changing the Strut Bar Cushion. The discussion and pictures
posted were for a first gen Lexus LS.
Question: Does the 99 LS 400 also have a strut bar cushion and are the steps to change it similar to the once that were posted?
I also get rattles in the steering when I go over bad cracked pavement -
is this also due to the strut bar cushion?
Thanks for your help - Your expertize and advice in this forum is very
helpful and appreciated.
