This is an interesting topic since its being develop as we speak. Couple of things I would like to share with our members. Stroking is no easy task. Couple of issues should be consider:
1. Rod clearance
2. Rod length
3. Piston design
4. Interferrence
1. Rod Clearance:
Some people think its so easy to sell a stroker crank like 3.85" stroke. If 3.85 stroke is possible, then there are few issues above need to be address. However, it will take more then a stroker crank to make the engine run. From what we found out, anything over stock 3.31" stroke will require block modifications. The uzfe block has limitation on clearance. Above and beyond stock stroke, then u will spend big money on modifying the block to make things clear.
2. Rod Length:
Assume this person made a 5.85" stroker crank. What size of rod would this person use? If the rods is too short, then the counter weight will hit the piston and if the rod length is too long, then your piston design will be compenmise with decrease compression height and ring lands. So choosing the right rod length is very essential.
3. Piston Design:
The pistons must have certain specs in order to function properly. As stated on number 2. The rod length will affect the piston design and compenmises. However, there are ways you can get around it, but still compenmises.
4. Interferrence:
Since the stroke increase from 3.31" to 3.85", interferrence is unavoidable. Rod swing or counter weight. Basically selling a 3.85" crank is only part of the solution. However, stroking is more complex than just adding stroke.
In conclusion, stroking will require lots of engineering and testing. Simple crank wont do it.
1. Rod clearance
2. Rod length
3. Piston design
4. Interferrence
1. Rod Clearance:
2. Rod Length:
3. Piston Design:
4. Interferrence:
