rivmasta
Hey all - Im gonna need some techy help with this one...
Im trying to put together the stock motor for EA so Im after a buttload of specs... any help at all would be appreciated!
Please remember this is for STOCK internals!
This will get me started, I can take a guess or get the program to take a guess with most of the rest. Then I'll do a dyno run and see how accurate it is. Then I'll start adding comp, cams, exhaust, intake etc and see what comes up. happy to test anyones pet theories as well once I have a baseline to work with.
250hp @ 5600
260ft/pd @ 4400
Block:
87.5mm Bore size
82.5mm Stroke
146mm Rod Length
10.0:1 compression ratio
Head:
33.6mm Intake Valve Diameter
Intake Port diameter (average before split)
Intake port length
Intake port angle (to deck)
28mm Exhaust Valve Diameter
Exhaust Port Eiameter (average before split)
Exhaust Port lenght
Chamber Design (Assume Pent roof similar to 4ag?)
Exhaust port angle (to deck)
1 @ 45 deg - No of valve angle faces at seat and degrees of each
Intake:
Runner diameter at head
Runner length
Throttle body CFM
OR
Throttle body diameter
Throttle body effective length (IE from air cleaner to Plenum)
Plenum chamber volume in CC's
Exhaust: stock mani remember! Is it cast iron?
Section 1 (from head to chamber)
Length
Diameter
Section 2 (from furthest runner to first restriction)
Length
Diameter
Cams: (95 - 97 LS400)
110 Intake Centerline ATDC
183 Intake Duration at .050"
7.65 Intake Lift
106 Exhaust Centerline ATDC
181 Exhuast Duration at .050"
7.75 Exhaust Lift
250hp @ 5600
260ft/pd @ 4400
Block:
87.5mm Bore size
82.5mm Stroke
146mm Rod Length
Head:
Intake port length
Exhaust Port lenght
Intake:
Runner length
Throttle body CFM
OR
Length
Diameter
Length
Diameter
7.65 Intake Lift
7.75 Exhaust Lift
